Eclipse crashes at startup after update V4.5.1 -> V4.5.2
General installation questions
Postby anbos » Mon Nov 15, 2010 9:42 am
Hello,
after update V4.5.1 -> V4.5.2 eclipse will always crash at startup. I cannot find any error log entry about this. If i erase the plugin manually from fetaures and plugins directories eclipse will startup...
Regards,
anbos
anbos
Re: Eclipse crashes at startup after update V4.5.1 -> V4.5.2
Postby micha » Mon Nov 15, 2010 11:55 am
Hello anbos,
What does crash mean? Does the eclipse gui come up at all? Does do splash screen show up?
In your workspace there is a directory called .metadata which contains a file .log that might contain information about what happens.
Maybe the plugin registry got invalid due to the failed updated. In this case it will help to start eclipse with the "-clean" option.
micha
Postby anbos » Mon Nov 15, 2010 1:50 pm
Hello micha,
the splash screen shows up, but then disappears without any error message. The .log file does not contain any information about this crash. I restarted eclipse with -clean option, but same problem exist. I removed the plugin manually. After it eclipse is working, but the perspective gets reseted. I installed the previous version 4.5.1 again and it works now!My collegue has the same issue with version 4.5.2
We will stay with V4.5.1 and try to investigate it again with V4.5.2 later
Regards,
anbos
anbos
Postby micha » Wed Nov 17, 2010 8:52 am
We could not reproduce the installation problem so far. Maybe your proxy has a wrong version of the plugins in its cache?
micha
Postby reto » Mon Nov 22, 2010 3:58 pm
Hello anbos
We released Version 4.5.3:
viewtopic.php?f=14&t=12
We hope this works better for you!
Regards,
Reto
reto
Return to Installation
