Error during update 4.5.1 -> 4.5.2
General installation questions
Postby anbos » Mon Nov 15, 2010 9:35 am
Hello,
today actifesource notified me about new actifsource V4.5.2. I started the update and during the download of new version an error appears:
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-11-15 10:22:57.012
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-11-15 10:22:57.012
!MESSAGE session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
!SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2010-11-15 10:22:57.012
!MESSAGE Unable to read repository at http://www.actifsource.com/updates/plug ... 121551.jar.
!STACK 0
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.getDecompressedStream(UrlConnectionRetrieveFileTransfer.java:542)
at org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.openStreams(UrlConnectionRetrieveFileTransfer.java:312)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98)
at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342)
at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288)
at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71)
at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:526)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:509)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:576)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:248)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:223)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:179)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:115)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:565)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.DownloadJob.run(DownloadJob.java:63)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
anbos
Re: Error during update 4.5.1 -> 4.5.2
Postby anbos » Mon Nov 15, 2010 9:37 am
I restarted the update and it works! It looks like a problem with connection: Siemens proxy or Actifsource server?
anbos
Postby micha » Mon Nov 15, 2010 11:41 am
Hello anbos!
Thank you for reporting the issue. We will check our servers to verify that the connection problem does not come from there.
micha
Return to Installation
Users browsing this forum: No registered users and 1 guest
